No Spark?
fastandyc
If you suspect that as the problem, then it will probably need either replacing, or you could have it rewound.
There is a company called west country windings which used to advertise in TMX and may well still do, I believe that they have the triggers, and may be able to supply you with one to try out before you spend the money on a full rewind, they seem pretty knowledgeable when it comes to beta stators.
I would be tempted to contact lampkins and ask for a stator to try out, easiest way by far, although not the cheapest.
Bob
  • Replies 31
