jbsjames Posted April 25, 2008 Report Share Posted April 25, 2008 (edited) Hi Treated myself to a repsol 4RT So far I love it , real solid and feels good . Just wanted to ask if the high idle is normal , as the previous owner said not to adjust it down as it will not start correctly ? Is there anything to watch out for ? or any thing i should do differently from my 2T , other than the obvious ? I also want to get the serial prog lead and software ?, I map VAG cars for a living so really interested to see if I can improve on what's there. I have looked over the manual but see nothing relating the the above ,also is there also a way to reset the throttle body or ecu ? Thanks in advance . James Edited April 25, 2008 by JBSJAMES Quote Link to comment Share on other sites More sharing options...
sideup Posted April 26, 2008 Report Share Posted April 26, 2008 (edited) Others may, (no will) correct if I am wrong but I don't think the 07 Repsols came with the programable ECU, only the 05 and 06 repsols. Software comes with the programable ECU, test box extra $. Can't find anything on the 07's but here's what is states on the 08's. (optional) 2008 Montesa Cota 4RT Repsol Replica A limited edition Montesa Cota 4RT has been released and designated the Repsol Replica Similar to the championship winning machine that is currently ridden by Dougie Lampkin, Takahisa Fujinami, Toni Bou & Laia Sanz it has many of the components used in their competition machines including: Carbon fibre fork brace Carbon fibre fork cover Carbon fibre headlight Carbon fibre muffler cover Carbon fibre clutch cover protector Repsol graphics/stickers Renthal trials handlebars Aluminium footrests Racing ECU (Electronic Control Unit) fully programmable (optional) Limited edition numbering plate Edited April 26, 2008 by sideup Quote Link to comment Share on other sites More sharing options...
sr34 Posted April 26, 2008 Report Share Posted April 26, 2008 (edited) its all been discussed here in detail previously as for the programable throttle body the previous reply was correct the 05 - 06 models were supplied with a single programable throttle body but alas thats now not the case there is a 2 map throttle body available if you search on line if you are still struggling to find any info after searching the relevant forum then i will forward some details to assist Edited April 26, 2008 by sr34 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted April 26, 2008 Report Share Posted April 26, 2008 (edited) sideup said: Others may, (no will) correct if I am wrong but I don't think the 07 Repsols came with the programable ECU, only the 05 and 06 repsols.Software comes with the programable ECU, test box extra $. Can't find anything on the 07's but here's what is states on the 08's. (optional) 2008 Montesa Cota 4RT Repsol Replica A limited edition Montesa Cota 4RT has been released and designated the Repsol Replica Similar to the championship winning machine that is currently ridden by Dougie Lampkin, Takahisa Fujinami, Toni Bou & Laia Sanz it has many of the components used in their competition machines including: Carbon fibre fork brace Carbon fibre fork cover Carbon fibre headlight Carbon fibre muffler cover Carbon fibre clutch cover protector Repsol graphics/stickers Renthal trials handlebars Aluminium footrests Racing ECU (Electronic Control Unit) fully programmable (optional) Limited edition numbering plate Similar to the championship winning machine ? What like 300cc ? 4 speed gearbox ? bluetooth programmable ECU ? and weighs less than a Gas Gas....... I think similar looking might have been more honest. Edited April 26, 2008 by Baldilocks Quote Link to comment Share on other sites More sharing options...
windlestone Posted April 26, 2008 Report Share Posted April 26, 2008 07 repsol comes with programmable throttle body only 08 doesn't Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 27, 2008 Report Share Posted April 27, 2008 be very careful with the kickstart try not to let it kick back it is a well known fault that the crankcases can break because of the compression it's not to bad if it kind of breaks once you just have to get it re-welded but if twice a new crankcase is needed Quote Link to comment Share on other sites More sharing options...
