Fan Not Working On My Sy Even With New Thermostst
godzilla
  godzilla said:
the fan is now working, why would it do this ? has it happend to you?
trace all the wiring from the stator and see if its worn through somewhere, normally the fan either works or doesn't in my experience rather than intermittent.
Under the seat is a black cylindrical unit with a pair of wires coming out. Check the connections and wires into it as the fan will not work without it. I had the wire to it melt on to the middle box. Sometimes the connector needs crimping up a bit.
Wot he said !
