Gasgas Tx320 1998 Clutch Lever
stingstiz
Hi,
I've just broken the clutch lever on my 1998 TX320 :rotfl: . The clutch lever is black and has AJP on it. Does anyone know if any other lever will fit (from another GasGas) or does it need to be for the TX320.
Many thanks for any info. :banana2:
Martin.
Hi,
Martin.
Martin,
I'm guessing that any of the AJP clutch levers up through 2001 will fit. I think the 98' clutch lever has an offset adjusting screw and in 2002, when the Pro came out they switched to a non-offset screw with the little Pro clutch master cylinder, but I think the "Edition" models made after that still carried the larger master cylinder with the offset lever.
Jon
