Triumph Twin Pvl Ignition Wiring
kelvfoozinda
I've recently got a norton frame with a triumph twin in it. It came with the electronic ignition bits tied to the bars, with no diagrams, so i'm a bit stuck with wiring.
From the stator there are two wires, Blue and Black.
The coil (with the two HT leads coming out, has two connectors.
There is another smaller box, this has a Red, Brown (which i assume is to earth as it had a ring crimp on the end), and a lead coming out with Blue and Brown wires, these have crimps on the end, that are easily accepted by the coil's two spade connectors.
I have no wiring diagram for this, so really need some help. If it help's i can get some pictures of the components.
Cheers, Kelvin.
  • 3 weeks later...
