Keihin Carb?
theshercorider
if its a new sherco you will need a smaller tank from a 2006 model as the Keihn doesnt fit with the new larger tank.
need a larger carb to airbox manifold, although some heat the standard up and stretch it to fit.
think you will loose some bottom end grunt but gain lots of top end power and revs.
The cabistany model came with the keihin carb, so the carb to airbox rubber from this model should do it .. call rathmells they will tell you for sure
they did not do a cabestany 125. distance from carb to airbox on 125 wont be the same as a 290. i think?
