Noisy Engine
aye sparticus
Always had a bit of noise from the clutch,
i believe this is to be expected on a gas gas
but i have just installed a flywheel weight
and now it seems even noiser....is this usual??
it goes when the clutch lever is pulled in
bit baffled!!
i know it's a bit of a numpty question
but im new to all this
thanks for any advice
bit baffled!!
My guess is that the "normal" clutch noise may be the fingers rattling a little, which is why it goes away when the servo cylinder presses on them (lever pulled in) and may be more noticible on clutches that have a lower finger height as the spring inside exerts less pressure.
Kinda difficult to diagnose the after/weight "noise" on a forum but it may, if it really is related to the flywheel weight, be a result of how the extra weight affects the normal speed-up/slow-down cycle of the crank during each revolution and the noise may be, in part, the interaction of the straight-cut gears (crank gear to clutch hub gear).
Just a guess at a possibility but I'm sure someone on the forum that has mounted a weight may have a more exact (and accurate) answer.
Jon
