jsygasgas Posted May 4, 2008 Report Share Posted May 4, 2008 Is the keihn carb really worth putting on my gas gas 125 Is it worth the money thnaks in advance Ben ! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 4, 2008 Report Share Posted May 4, 2008 jsygasgas said: Is the keihn carb really worth putting on my gas gas 125Is it worth the money thnaks in advance Ben ! It really depends on you Ben. The Keihin is a trade off, it will give smoother low rpm power and a lot more high rpm power. So if you are fiving sections because you bke doesnt rev high enough then it could be worth doing. However if your not having that problem keep your money. Quote Link to comment Share on other sites More sharing options...
dgshannon Posted May 4, 2008 Report Share Posted May 4, 2008 jsygasgas said: Is the keihn carb really worth putting on my gas gas 125Is it worth the money thnaks in advance Ben ! Note the BIG GIANT red notes, as you come into this area. If your topic is related to a specific brand of bike then please post in the dedicated Forum for that brand of bike. Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted May 4, 2008 Report Share Posted May 4, 2008 jsygasgas said: Is the keihn carb really worth putting on my gas gas 125Is it worth the money thnaks in advance Ben ! The answer is mate yes i've just got one in my 08 125 racing it is fantastic it gives a real clean smooth top end performance & uses only half the amount of fuel than what the dellorto used to Quote Link to comment Share on other sites More sharing options...
atomant Posted May 5, 2008 Report Share Posted May 5, 2008 As stated - The Keihin is smooth at the bottom and allows the engine to rev very high, It's response is faster than the dellorto as well. Take a look at these short clips of Ross on a JST GasGas 125cc. This has a Keihin fitted and when set-up correctly, it is pretty sweet! Quote Link to comment Share on other sites More sharing options...
