mik60ish Posted May 4, 2008 Report Share Posted May 4, 2008 Hi All I need to make a tee bar for a Yamaha TY 250 mono to strip the forks does anyone know the size of the hexagonal IE to suit a for instance (19mm) socket not sure of size just guessing? Cheers Mike Quote Link to comment Share on other sites More sharing options...
tt5th Posted May 5, 2008 Report Share Posted May 5, 2008 I'm afraid I don't know the exact size but I made one that works fine on most forks by welding the tip of a wide (about 10mm) flat head screwdriver onto the end of some re-bar. Its a bit cowboy I know but just jam it in and it works fine. To date its done - FZR, GSX, TY, Scorpa Easy, and XV forks without a problem. Quote Link to comment Share on other sites More sharing options...
kevin j Posted May 6, 2008 Report Share Posted May 6, 2008 I don't have my notes files here, but I think it was 22 mm. That is just under 7/8 inches and I think I used 7/8 across flats nut. I welded it to end of a piece of tubing, then welded a socket to the top end to accept a 3/8d rive ratchet. Easy, and way better than the broomstick/wood/tape/screwdrivers methods. I don't know how to post a pic here but can send you one. kcj Quote Link to comment Share on other sites More sharing options...
mik60ish Posted May 6, 2008 Author Report Share Posted May 6, 2008 Thanks Kev I know what you mean I had a tee bar mid 80's but lost it over the years just wanted to know the hex size? Cheers Mike Quote Link to comment Share on other sites More sharing options...
kevin j Posted May 9, 2008 Report Share Posted May 9, 2008 yes, 22 mm, 7/8 inch across flats. couldn't find notes, but did find the tool. kcj Quote Link to comment Share on other sites More sharing options...
