gser Posted May 6, 2008 Report Share Posted May 6, 2008 (edited) IS the front disc on a 2002 TXT250 designed to float, or should it be solid. My disc has movement in it, and I am wondering if I need new bolts and spacers? Edited May 6, 2008 by gser Quote Link to comment Share on other sites More sharing options...
jse Posted May 6, 2008 Report Share Posted May 6, 2008 IS the front disc on a 2002 TXT250 designed to float, or should it be solid. My disc has movement in it, and I am wondering if I need new bolts and spacers? The front disc is a "floater" and should be a little "loose" as that's how it aligns itself with the pads in the caliper. You didn't specify if your bike was a "TXT Edition" or "TXXI Pro" so I looked at the parts list for the Edition model and then at my own bike, which is an 02' Pro and they both use the floating disc (as expected, as they both use the same forks). Not to worry. Cheers. Jon Quote Link to comment Share on other sites More sharing options...
