shercoman2k8 Posted May 6, 2008 Report Share Posted May 6, 2008 hey guys, Im havin a wee bit of a problem, my sherco will just not idle, i wait for the bike to warm right up and it still wont idle, ive adjusted the tickover screw a few to all imagiable positions and no difference, my thermostat is broke so fan is on all the time. could this be causing it and how? Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 6, 2008 Report Share Posted May 6, 2008 Hi there, i used to have the same problem with mine.. i fixed it by cleaning the petrol filters carb and putting fresh fule in.. there is a filter in the tank remove the petlock and unscrew the black plastic filter and clean it . then remove the filter from the carb. this is a small mesh one from behind the bit the fule line goes that onto the carb. while you are there give the carb a clean by removeing the float bowl an blowing throug the jets. put it back together, put some new fule in and it should be better. sorry if any of that was a bit vague. if i is not any better get in touch. Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted May 6, 2008 Author Report Share Posted May 6, 2008 (edited) cheers for the quick reply, clean the carb after ever ride up here, its all rivers, burns and lots of mud! umm havent checked the fuel filters yet though, will check after school tomorrow if i dont go to the scottish. Edited May 7, 2008 by shercoman2k8 Quote Link to comment Share on other sites More sharing options...
copemech Posted May 7, 2008 Report Share Posted May 7, 2008 Usually, you may never see the offending dirt or water after disassembly! It is usually related to a blockage in the pilot (small)jet circuit. The carby's need to be cleaned immaculate, including the banjo inlet screen on the dellorto, and all passages and jets blown out with air. You should remove jet so you can see through it. One drop of water condensation will cause erratic idle fluxuations and low speed running, one spec of sand, you are done! That is just how sensitive this stuff is! Get the picture? And although I try to practice what I preach does not mean I strip things every ride as I am also lazy, yet dusty conditions here may be just as bad as muddy conditions there. Short bowl vent tubes(1.5-2.0 inch) seem to help keep stuff out as well. First sign of trouble and it is off! Hope that helps, Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted May 15, 2008 Author Report Share Posted May 15, 2008 still does not tick over guys, any more ideas? Quote Link to comment Share on other sites More sharing options...
copemech Posted May 15, 2008 Report Share Posted May 15, 2008 (edited) Well, can you seem to maintain a reasonable idle using the throttle? You should really post in the Sherco forum for further input from others I think. Can you see through the pilot jet? Edited May 15, 2008 by copemech Quote Link to comment Share on other sites More sharing options...
jse Posted May 15, 2008 Report Share Posted May 15, 2008 Usually, you may never see the offending dirt or water after disassembly! It is usually related to a blockage in the pilot (small)jet circuit. The carby's need to be cleaned immaculate, including the banjo inlet screen on the dellorto, and all passages and jets blown out with air. You should remove jet so you can see through it. Copey's got the right idea. One thing to remember is you really need to remove all the jets/tubes you can from the carb and always blow the compressed air in the OPPOSITE direction that it flows in the carb body. I've seen riders just blow air into the bell intake ports, which usually further lodges the offending particles deep inside. Jets should be very carefully checked with a very fine wire (brass if possible, like from a wire brush) that is much smaller than the jet opening so it does not ream out the hole. Sometimes a transparent piece of grit (quartz, for example) will fool the observer into thinking the jet hole is clear and a lot of pilot jets are only .014" in diameter. Jon Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted May 21, 2008 Author Report Share Posted May 21, 2008 All right guys, Respect. The pride and joy is running perfect yet again cheers atb, jamie Quote Link to comment Share on other sites More sharing options...
copemech Posted May 22, 2008 Report Share Posted May 22, 2008 Good job then!!!!!!! Did you actually SEE anything? Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted May 30, 2008 Author Report Share Posted May 30, 2008 No coudnt see a peice of grit, sand or dirt. Done what you all said. Then a few days later started doing it again. This time sorted easily, dirt blocking the drain hole in my airbox. Typical Quote Link to comment Share on other sites More sharing options...
