Gear Oil Vent/overflow
russd
In regard to the (2) ports in the case, one on the clutch side, the other on the flywheel side...
My '96 Techno connected these two ports with a single line. Overflow would dribble gear oil into the flywheel side.
My '04 Rev3 has 2 tubes, each going from the repective port to the ground.
Interestingly, the Techno was spotless and corrosion-free under the flywheel yet my Rev3 is dry with moderate corrosion...
Which plumbing is best?
