Help!
spikeycorsa1983
If you have only replaced the clutch cover then you shouldn't need to bleed it, if you have had the system apart then you will. That said bleeding it won't do it any harm, the procedure is much the same as bleeding the front brake, have a search on the forums for any tips, brake bleeding is quite a common thread.
Bob
