shercoman2k8 Posted May 9, 2008 Report Share Posted May 9, 2008 (edited) I have recently moved from a completely tricked out beta 250 with wavey discs and a set of the new 08 paioli ceriani forks,and about Edited May 9, 2008 by shercoman2k8 Quote Link to comment Share on other sites More sharing options...
copemech Posted May 10, 2008 Report Share Posted May 10, 2008 I have seen some run the lighter flywheel, turned down about 5-6mm i think, to reduce the weight by about 1 pound. This does not cost a lot if you find a good machinist, but may not be for everyone. The j-peg half back pegs from RYP seem to be the ones of choice for the ones like Smage, me too! Quote Link to comment Share on other sites More sharing options...
bama Posted May 10, 2008 Report Share Posted May 10, 2008 Most seem to have a high compression head, but that makes the $$$$$ go up, seen some run 48 tooth sprockets as opposed to the stock 44. Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 10, 2008 Report Share Posted May 10, 2008 A Keihin carb is what you need, if you mess with the flywheel wheel it will make the bike useless for uk trials. why dont you call rathmells on 01423772885 someone there will be able to advise you. also have a look at what the new academy shercos and the paxau bikes have that yours has not. Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted May 10, 2008 Author Report Share Posted May 10, 2008 Cheers for the replies, Ill go check a mate duncan's bike as he has just got the new academy bike. jamie Quote Link to comment Share on other sites More sharing options...
