matthew Posted May 11, 2008 Report Share Posted May 11, 2008 Help ! Can anyone give me advise on a 125 06 sherco? The problem is the plug is as sooty as hell ive cleaned the carb/ cleaned the exhaust down pipe / changed the fuel to 99pecent octane and oil level to 65 ml per 5letres / new air filter /decoke cylinder head/ new platinum plug/ dropped the needle valve one notch/ pilot air adjustment screw 3 and one quarter out/ The problem is still there the bike runs fine but keeps knocking the plugs out.. Cheers. Quote Link to comment Share on other sites More sharing options...
johnkennedy Posted May 11, 2008 Report Share Posted May 11, 2008 I had the same sort of problem, check your pilot jet is a 36. I used to have a 38 in mine that was letting too much fuel thruogh, tryed a 34 today and wasnt good. 36 is reccomended Quote Link to comment Share on other sites More sharing options...
matthew Posted May 11, 2008 Author Report Share Posted May 11, 2008 Ok thanks, I'll try that. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
