dfwilson Posted May 12, 2008 Report Share Posted May 12, 2008 My 03 SY-250 would not run today so I took it apart and the inside of carb and intake was coated with a white powdery residue. I have never seen this before. I was able to wipe the residue off with a cloth. It didn't disolve with carb cleaner. I switched to Motul 800 full synthetic a while ago. I used to use Motul 600 full synthetic and never had this problem. Has any one noticed this problem with Motul 800? I also switched from leaded race gas to unleaded about the same time. Any help would b appreciated. Thanks, DFW Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 12, 2008 Report Share Posted May 12, 2008 Hi there, you should be runnung the bike on semi synthetic. this will stop the exhaust clogging up ect. it was told this by nigel birkett. not sure if this is why you are haveing problems as i used fully synth motul on other bikes with no problem. Quote Link to comment Share on other sites More sharing options...
tt5th Posted May 12, 2008 Report Share Posted May 12, 2008 (edited) White powdery residue ey? Not being doing any border crossing recently have you? Sounds the like stuff I find on inside of my bikes carbs when they've been stood for a while. I used to solve it by turning off the fuel and running till the carb was dry before I left them but this was on 4 strokes and I'm not sure how sensible this would be to do on a 2 stroke due to lubrication. I'm also using unleaded if this has any bearing on anything. Edited May 12, 2008 by tt5th Quote Link to comment Share on other sites More sharing options...
peterb Posted May 31, 2008 Report Share Posted May 31, 2008 Hi DFW, Usually caused by moisture in the carb, water getting in and not being cleaned out. Completely strip out the carb, totally, scrape off residue where you can and blow out the passageways. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 3, 2008 Report Share Posted June 3, 2008 If it's pump gas it could be due to moisture absorbed by the ethanol. Quote Link to comment Share on other sites More sharing options...
