Carb Removal
fozza321
fozza321,
You can leave it on the side stand if you remove the fender, aluminum brace, and airbox. You have to have to remove the slide first and then if you hold your mouth just right you can slip the carb out. Just remember the the fuel line goes under the rear brake reservior.
Ciao
DFW
ıs there an easıer way of removıng the carb on an 06 sy250? when ı last dıd ı had to take the top bolt from the shock off??
any help apprecıated.
Did mine the other night, but you may as well remove the shock mounting (1 minute job) because its the last obstacle after removing, 'fender', silencer, alloy subframe and air box! I had also removed the rear wheel which made swinging the shock out of the way a piece of cake.
on my 06 I removed the five bolts that hold the subframe onto the main frame ( one actually fastens on to the airfilter box) and left the rear silencer and airbox attached to the subframe. Once all this is off you can wiggle the carb out with the shock in place. The whole process still takes 20mins though
Gents, believe me, it is a lot easier to get at the carb if you take the whole lot off [mudguard (3 screws) sub-frame(7 screws) air box (as subframe + 1 screw), silencer (part of screws that go with sub-frame) & shock bolt]. I had the whole lot off and back on in 1/2hr. Wouldn't like to do it other than in the comfort of my garage though!
