theshercorider Posted May 14, 2008 Report Share Posted May 14, 2008 The other day i got some fork guards for my 08 but they dont fit very well with the disc protector and so rub against the bottom yolk. Any easy way to do it. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 15, 2008 Report Share Posted May 15, 2008 If you got them plastic ones, you will need to do a fair bit of trimming to fit! And if you gpt the full length uppers that the minders hate, cut them off! Quote Link to comment Share on other sites More sharing options...
rlracer Posted May 15, 2008 Report Share Posted May 15, 2008 They may need trimmed a bit, if they are the full lenght and that is what you want don't cut them, mount it on the fork leg apply a little heat from a heat gun and gently pull it out a little. Be careful it only takes a little heat and a little move ment. I've done this several times. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 15, 2008 Report Share Posted May 15, 2008 Maybe if you cut those long guards off, more folks would consider catching you RL. You are running out of body parts to break! Quote Link to comment Share on other sites More sharing options...
rlracer Posted May 15, 2008 Report Share Posted May 15, 2008 Possable Copie, but I have seen enough upper fork legs with garf marks in them from getting knicked by a rock that i'll keep them on. Any way my 08 that I bought in November still looks new, maybe I can ride it this weekend. Quote Link to comment Share on other sites More sharing options...
