1976 Sherpa 325
twinshockdude
Are you having problems with the standard set up?
I only ask as I am on my third Sherpa,a 1977 190 and it has a great spark with the standard points set up.I had a 92 and a 198b and once the low tension coil was re-wound on the 198 I never had any more trouble with it.The timing is easy enough to set up with the points,a bit of thin paper,a TDC gauge with a dial gauge attached.
I'm not knocking the electronic systems,fit and forget,great.I suppose I like the satisfaction of setting an engine up myself and riding in a trial with no problems.
