pat64 Posted May 21, 2008 Report Share Posted May 21, 2008 hello folks iam thinking about converting my crap front drum brake to a disc.it is my understanding that the forks and disc from a fantic will fit,can anyone tell me what model fantic i need to get the parts from. sorry if this has been posted before. cheers Pat..... Quote Link to comment Share on other sites More sharing options...
woody Posted May 21, 2008 Report Share Posted May 21, 2008 Not sure you'll get one to go straight in. I'm not familiar with all of the Fantic model's forks but most if not all up to the upside down fork models are 35mm. The Section model's may be larger than 35mm, not sure. Not sure which Yam you mean but the mono Yam forks where they fit in the yokes are 36/37mm so 35mm forks won't clamp up. The twinshock Yam is 34mm so yokes are too small. If it is a Yam mono you should be able to get a complete front end from a Pinky which will go straight in. Probably a better brake on that as well compared to the earlier Fantics/Betas etc. Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 21, 2008 Report Share Posted May 21, 2008 My mate is selling a ty250 mono talon front disc conversion. it has everything you need includeing a gold front wheel. pm me if you want more info Quote Link to comment Share on other sites More sharing options...
kevin j Posted May 22, 2008 Report Share Posted May 22, 2008 GasGas front wheel and 4 piston AJP caliper and master cylinder and hose. All slip on, no modifying the original forks. Way better than the older conversions. Search on this site, I posted info and pics in the past. I can email you the dwg of the bracket with all the dimensions. k Quote Link to comment Share on other sites More sharing options...
pat64 Posted May 24, 2008 Author Report Share Posted May 24, 2008 thanks for the help guys cheers Pat..... Quote Link to comment Share on other sites More sharing options...
