Can't Get My Right Side Bar End Off, Seems So Be Spinning Inside. Need Help
pillar
How can I get my bar end off???? I loosend off the allen key bolt but it just keeps spinning. It backs outs a bit but thats it. I can spin the red end around but can't get the dang think off. I have a new grip just itching to get on the throttle but this side aint budging.
What can I do??
Please help quickly!!
Thanks again.
I had the same problem with the Hebo aluminium bar ends, came out when i spayed some WD-40 in. You will have to give it all a good clean with carb cleaner before putting it back in otherwise you wount be able to tighten it up again.
Hope it helps
Tom
When I took mine off I had to use vice grips on the bar end then loosen the allen then twist back and forth with the vice grips to get them out. After regripping I thuroughly lubricated the threads on the inside that tighten the bar end. I also destroyed 2 allen wrenches because the bolts were stuch.
Good times.
