yamahaty250xox Posted May 29, 2008 Report Share Posted May 29, 2008 (edited) hi my 07 rev 3 125 has developed a bit of a splutter. it wont fully rev out and half way through the rev range it splutters. i had the carb off earlier this week and all is clean in there. although come to think off it the splutter started after i had it off. it does seam to get better if the petrol is turned off and run for a while. im using the recomended 70:1 petrol mix with castrol tts any help apprecated max Edited May 29, 2008 by yamahaty250xox Quote Link to comment Share on other sites More sharing options...
betarev3 Posted May 29, 2008 Report Share Posted May 29, 2008 You could easily have disturbed some crap when you removed the carb, so remove it again and inspect everything again carefully. Ensure no air leaks at connections when re-assembling. If no improvement, at least you can eliminate the carb completely. Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted May 30, 2008 Author Report Share Posted May 30, 2008 hi thanks for all the help i have just taken the carb off and cleaned all the jets again but the problem still persists. when i first took my carb off i foolishly placed the floats in upside down thus not letting any fuel in. i realised i had done this so took it off again and truned them round. could this have bent the float tangs to a differnt place? max Quote Link to comment Share on other sites More sharing options...
mikee Posted May 30, 2008 Report Share Posted May 30, 2008 Hello Max, Have a look HERE tells you all you need to know about dellorto carbs. Don't think i be ridding sunday as it looks like the main bearings and crank seals have gone on the GASSER.... mike. Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted May 30, 2008 Author Report Share Posted May 30, 2008 thanks mike ohh dear shame about your bike. how long do you think you will take to have it done? will you still be comming along on sunday? max Quote Link to comment Share on other sites More sharing options...
