dannymagic Posted June 2, 2008 Report Share Posted June 2, 2008 Going to look at one anything I should look out for? Quote Link to comment Share on other sites More sharing options...
copemech Posted June 3, 2008 Report Share Posted June 3, 2008 Main things that come to mind are : Excessive slack in the rear linkage, by lifting the rear Excessive slack in the main bearings, by lifting the flywheel with the (3screws and cover off) Then you can go to chain gears and wheel bearings! Steering head bearings turn smoothly! Do not expect perfection, but workable at that year, much depends upon proper maintenance~ M2C Quote Link to comment Share on other sites More sharing options...
dannymagic Posted June 10, 2008 Author Report Share Posted June 10, 2008 Well I ended up buying it, the rear linkage was shot but the motor sounds well and everything else is ok, the lad was after a quick sale to pay for his CORGI registration for work so I got it for a reasonable Quote Link to comment Share on other sites More sharing options...
copemech Posted June 12, 2008 Report Share Posted June 12, 2008 Well I ended up buying it, the rear linkage was shot but the motor sounds well and everything else is ok, the lad was after a quick sale to pay for his CORGI registration for work so I got it for a reasonable Quote Link to comment Share on other sites More sharing options...
