roberto Posted June 3, 2008 Report Share Posted June 3, 2008 Here is the situation. I tried a 2006 GG TXT250 yesterday which is almost brand new. The engine sounded excellent but when I tried the bike, the shifter mechanism didn Quote Link to comment Share on other sites More sharing options...
pancho247 Posted June 3, 2008 Report Share Posted June 3, 2008 I have a 2008 250 Pro and i have a similar problem, the change between 4/5 is very clonky, 1-4 is ok, so is 5/6 but bit concerned if this is an early sign for an exploding gearbox????? Quote Link to comment Share on other sites More sharing options...
roberto Posted June 3, 2008 Author Report Share Posted June 3, 2008 Was your bike always like this? Or is this something that has just come up. This bike is absolutely new, I don Quote Link to comment Share on other sites More sharing options...
pancho247 Posted June 3, 2008 Report Share Posted June 3, 2008 yeah, the bike has been like it from day 1. i have had gasgas trials before not before the pro, had no issues then Quote Link to comment Share on other sites More sharing options...
laser1 Posted June 3, 2008 Report Share Posted June 3, 2008 In general, trials bikes tend to be clunky shifting bikes. They tend to be hard to get into gear, but also dont tend to pop out of gear either. What you describe could certainly be a sign you need an adjustment - you will need to try it to find out for sure. There are a few threads in the GG forum that explain the procedure and what to look/listemn for. I think JON did a write up on this, but not certain. Also, on pro models, the 1st gear and 4th gear shifts are especially clunky. You can find a Pro model transmission power transfer diagram here and makes it clear why it would be the case. http://www.trialspartsusa.com/diagrams/Pro...ion%20gears.doc In terms of it being a relatively new bike - things like this can happen (especially with this sort of item ) and are one of the roles the dealers play in the supply chain. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted June 4, 2008 Report Share Posted June 4, 2008 Just be firm (not violent) when changing between 4th & 5th and 5th & 6th. There's a huge gap in the ratios between those gears compounded by the rather clever selection mechanism that Gasser have patented (8 gears in a 6 speed box, as opposed to 12). It's normal. Quote Link to comment Share on other sites More sharing options...
peterb Posted June 4, 2008 Report Share Posted June 4, 2008 Hi Roberto, What you describe, as Tim said, is quite normal for this particular motor. There is quite a clunk between 4th and fifth and this is nothing to be alarmed about. 1st through 4th is a little notchy I guess, but the gear lever should certainly return smoothly. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
roberto Posted June 4, 2008 Author Report Share Posted June 4, 2008 Thanks for the info, I Quote Link to comment Share on other sites More sharing options...
