dougalthedog Posted June 5, 2008 Report Share Posted June 5, 2008 TY250 Mono Normally starts 1st or 2nd kick, been stood for a few weeks. Started no problem on Tuesday, came to start yesterday - no joy. Checked good spark and fuel getting through. Ive had the carb off and blown through with an airline - no gunge in float bowl. Only thing I can think of is that the fuel has gone off. If I dip the plug in some fuel drained from tank and light with a cig lighter it burns. If I remove wet plug from bike it will not burn??? Can anyone help please - its doing my head in. Thanks in advance Quote Link to comment Share on other sites More sharing options...
mikee Posted June 5, 2008 Report Share Posted June 5, 2008 First step i would take is a new plug or dry your old plug out with a air line. Still no joy, then put some fersh petrol with a clean DRY plug. see how that goes. Quote Link to comment Share on other sites More sharing options...
dad Posted June 5, 2008 Report Share Posted June 5, 2008 Fresh fuel is the key in this case I think. I have been fooled into thinking that fuel I mixed last week would be good for this week. think about what has changed since you last started the bike, have you adjusted the timing, no,then what ? Peter Quote Link to comment Share on other sites More sharing options...
betarev3 Posted June 5, 2008 Report Share Posted June 5, 2008 Hi - a good spark in air may not be very good under pressure in the engine. therefore try a new plug - this should eliminate one thing. If still no joy then it must be fuel quality or possibly fuel contamination (with water?) Is ther any chance water could have got into the crankcase? Quote Link to comment Share on other sites More sharing options...
