nigel dabster Posted June 8, 2020 Report Share Posted June 8, 2020 On 6/12/2008 at 4:35 PM, paul w said: 7psi front 4psi rear, as a starting point. too high for front tad low on rear for average weight rider. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 8, 2020 Report Share Posted June 8, 2020 18 hours ago, jimmyl said: No but if I knew I was riding cold streams all day I wound probably set slightly higher at the start of a trial. likewise wouldn’t park the bike in a stream then adjust pressures - Same if I had just done a bit of roadwork my guess is on all but the coldest days youre riding at 4.5psi rear and 6 front which is where i like to be, maybe 5.5 front if the trial has soft mud or cambers. 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted June 8, 2020 Report Share Posted June 8, 2020 (edited) On 6/7/2020 at 3:14 PM, jimmyl said: No but if I knew I was riding cold streams all day I wound probably set slightly higher at the start of a trial. likewise wouldn’t park the bike in a stream then adjust pressures - Same if I had just done a bit of roadwork Maybe its time you fitted one of those wireless pressure monitor caps like in cars or road bikes. Edited June 8, 2020 by faussy Quote Link to comment Share on other sites More sharing options...
jimmyl Posted June 8, 2020 Report Share Posted June 8, 2020 4 hours ago, faussy said: Maybe its time you fitted one of those wireless pressure monitor caps like in cars or road bikes. No Got one of those new fangled things called a pocket 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 8, 2020 Report Share Posted June 8, 2020 4 hours ago, faussy said: Maybe its time you fitted one of those wireless pressure monitor caps like in cars or road bikes. That is like my wife looks at her fit bit on her wrist to see if her phone is ringing. 2 Quote Link to comment Share on other sites More sharing options...
