joandemma Posted June 12, 2008 Report Share Posted June 12, 2008 Does anyone know if a rear brake caliper from a Pro will fit on a 2002 txt edition, as I am always having bother with 4 pot model caliper. Cheers in advance. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 13, 2008 Report Share Posted June 13, 2008 The Pro's have a threaded steel peg to locate the caliper on the swinging arm. This isn't insurmountable if you haven't got one, but if your rear disc has five mounting bolts you'll need a different rear hub too. The Pro disc has four mounting bolts and the hub is machined to clear the caliper. Quote Link to comment Share on other sites More sharing options...
hrc1 Posted June 13, 2008 Report Share Posted June 13, 2008 Yes, the AJP 4 pot caliper is a straight swap for the troublesome Hebo caliper. I've done this on my Pampera. Quote Link to comment Share on other sites More sharing options...
