Broadburner Posted June 21, 2018 Report Share Posted June 21, 2018 On 17/06/2008 at 6:53 AM, edholland said: Hello Dave, I had the same question a while back and found this list posted bij Jon (JSE) this was for a 2004 TXT Pro 300. Maybe ask Jon first if the 2005 model uses the same torque specs. Foot pounds /Newton Meters Front Wheel Axle_______________ 30 to 37/ 40 to 50 Chassis to swingarm fastener_____ 44 to 52/ 60 to 70 Upper shock absorber fastener____ 30 to 37/ 40 to 50 Lower shock absorber fastener____ 30 to 37/ 40 to 50 Handlebars___________________ 13 to 18 /18 to 25 Hand levers___________________ 5 to 7 /7 to 10 Radiator fasteners______________ 13 to 18 /7 to 10 Front bridge wing_______________ 5 to 7 /7 to 10 Brake pedal___________________ 20 to 24 /27 to 32 Muffler fasteners_______________ 13 to 18 /18 to 25 Rear wheel axle________________ 30 to 37 /40 to 50 Rear brake caliper fastener_______ 20 to 24 /27 to 32 Front brake caliper fastener_______ 20 to 24 /27 to 32 Exhaust pipe elbow fastener______ 20 to 24 /27 to 32 Engine fasteners________________ 13 to 18 /18 to 25 Rear brake pump fastener________ 5 to 7 /7 to 10 Spark plug_____________________ 8 to 9 /11 to 12 Ignition fasteners_______________ 5 to 7/ 7 to 8 Clutch fasteners________________ 5 to 7 /7 to 8 Cylinder stud bolt fasteners_______ 18 to 20 /25 to 26 Reed fasteners_________________ 5 to 7/ 7 to 8 Clutch ground fastener___________ 2 to 3 /3 to 4 Crankcases fasteners____________ 5 to 6 /7 to 8 Water pump cap fastener_________ 5 to 6 /7 to 8 Clutch cap fasteners_____________ 5 to 6 /7 to 8 Flywheel fastener_______________ 30 to 32 /40 to 42 Water fastener_________________ 7 to 8 /10 to 12 Ignition cap___________________ 5 to 6 /7 to 8 Engine drain plug_______________ 9 to 10 /12 to 14 Kickstart pedal screw____________ 9 to 10 /12 to 14 Shift pedal screw_______________ 5 to 6 /7 to 8 Cylinder head screws____________ 8 to 10 /11 to 14 Cylinder nut___________________ 18 to 20 /25 to 27 Cheers, Ed Live saver pal, I've been googling torque specs (I'm a bit OCD when it comes to torque) for ages. Thank you!! Quote Link to comment Share on other sites More sharing options...
