Oil Level In Pro -03
erixon
I'm about to change my transmission oil....in the service manual it says: The oil level must be between the minimum and maximum indicators??? I can't see any indicators in the window??? I't also says that the system holds 550cc of oil.....should i just drain the oil and fill up 550cc of new oil ?
Ignore the indicator window, it's only good to tell you if it's empty. I find 450ml is fine for a normal oil change. If you were doing a tear down and complete cleaning 550ml might work fine, but I find it blows off under normal oil change conditions.
