bingo Posted June 19, 2008 Report Share Posted June 19, 2008 hello, do you fit your handlebars and live with them as they come or do you cut a bit off each end? bingo Quote Link to comment Share on other sites More sharing options...
zippy Posted June 19, 2008 Report Share Posted June 19, 2008 I cut about a half inch off each side. I use Pro-Taper bars and they have cut marks on them makes it easy. With the bars wider it puts my wrists at an odd side angle. I try to make it so that my hand and fore arm are "in-line" with each other. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 20, 2008 Report Share Posted June 20, 2008 Generally i'd leave them. I is very difficult to cut the mettal back on if you don't like them short so try someone elses bars for feel at a trial If you were short, i'd consider cutting 10mm off each side. If you are tall get adaptors to raise the bars 20mm. Ralphy Quote Link to comment Share on other sites More sharing options...
grindrod Posted June 20, 2008 Report Share Posted June 20, 2008 I am 5'7" and have just cut half an inch off each end of the bars on my Beta 200 and rotated them towards me a bit, the difference on tight turns is huge. I often struggled on tight turns but a session with Steve Saunders showed how it should be done, I was still struggling a bit with tension in my outside arm rather than the inner arm as taught by Steve so I asked the team at BVM and they suggested that, given my size, I should shorten the bars and rotate them back towards me a little. What a difference!! the technique taught by Steve makes sense and works!!! Quote Link to comment Share on other sites More sharing options...
ikb Posted June 20, 2008 Report Share Posted June 20, 2008 I cut about 20mm off each end of mine as I am below average (in most things!!!). Its something I have always done, when I ride other peoples bikes they feel a bit wide!! Quote Link to comment Share on other sites More sharing options...
fester Posted June 26, 2008 Report Share Posted June 26, 2008 i just cut the throttle side on mine because of the ball bearing end cap,just the width of the bearing Quote Link to comment Share on other sites More sharing options...
firstgear Posted June 26, 2008 Report Share Posted June 26, 2008 For me its the wider the better. A wide bar seems to help me find balance better/faster and gives me a solid feel on the bike. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 26, 2008 Report Share Posted June 26, 2008 For me its the wider the better. A wide bar seems to help me find balance better/faster and gives me a solid feel on the bike. I find the same, when Ive cut bars down in the past I cant balance the bike as good and I find the steering a bit wierd Quote Link to comment Share on other sites More sharing options...
ham2 Posted June 28, 2008 Report Share Posted June 28, 2008 I find the same, when Ive cut bars down in the past I cant balance the bike as good and I find the steering a bit wierd Cutting the bars is a big no-no for me. When I've tried the 'narrow-bars' method I found that it generates too much load on my arms and gives me tennis elbow. Quote Link to comment Share on other sites More sharing options...
jsygasgas Posted June 28, 2008 Report Share Posted June 28, 2008 Being a junior quite a few people cut there bars down and i've ridden there bikes me being 6 ft my self obviously i wouldnt like it particualary but there specifically made for trials and i dont think there deigned to be tampered with i guess it just affects the balance of the bike ~? Quote Link to comment Share on other sites More sharing options...
