supersherco Posted June 22, 2008 Report Share Posted June 22, 2008 orite might sound a bit stupid but i got a slight bit of movement when i clean the engine and its not to good halfway through a section........any ideas how to cure it. thanks in advance alex Quote Link to comment Share on other sites More sharing options...
lee harris Posted June 23, 2008 Report Share Posted June 23, 2008 i dont understand the question! bowel movment when you clean the engine? wats it got to do with a clutch Quote Link to comment Share on other sites More sharing options...
bikespace Posted June 23, 2008 Report Share Posted June 23, 2008 I get it too - I usually just nip my back brake on. I'm guessing mine could be age - I reckon after nearly 5 years of use mine may be on it's last legs. Be interesting to hear if it's age related or just a common problem. Quote Link to comment Share on other sites More sharing options...
copemech Posted June 24, 2008 Report Share Posted June 24, 2008 If lever is adjusted properly, yet you still get too much creep when the lever is pulled in, it is likely your plates are warped a bit. These things recieve a lot of abuse, and dependant upon just how much it annoys you, a fresh set of frictions and steels will keep you happy for a long time, well usually. Someone like Smage, for example, may go through a couple of clutches per year as I understand, but usually that is not the case. I do think the 125's are much harder on clutches btw. Quote Link to comment Share on other sites More sharing options...
