mattylad Posted June 24, 2008 Report Share Posted June 24, 2008 I need to fit lights to my RTL, does anyone have a simple wiring diagram, the less wires the better! Quote Link to comment Share on other sites More sharing options...
rené delvaux Posted June 25, 2008 Report Share Posted June 25, 2008 Here is a scan from my 89*rtl250S owner manual and parts list. By alfathailande By alfathailande I don't know if the drum brakes models were in 6 or 12 volt in order to use the proper regulator-rectifier If your bike is not an european model, there is no lighting coil in the stator. In this case you can may be find a coil from a small Honda engine. My RTLs were imported from Japan thus no lights. When I ride a little bit far from home, I fit a set of lights for bicyle. Quote Link to comment Share on other sites More sharing options...
mattylad Posted June 26, 2008 Author Report Share Posted June 26, 2008 Thanks Quote Link to comment Share on other sites More sharing options...
