erixon Posted August 29, 2004 Report Share Posted August 29, 2004 I have a gasgas 280 - 03 and i have some problems to get a good idling... when the bike is chocked the idling is fine when i put the chocke down it sounds very strange like uneven idling.... i have tested to turn the large screw on the side of the carbourator....is that screw both for idling and petrol-air mixture??? Does that screw have any standard setting ?? When the chocke is down i think the throttle is to sensitive....it goes up in rpm when i bearly thouch the trottle??? Quote Link to comment Share on other sites More sharing options...
jtt Posted August 30, 2004 Report Share Posted August 30, 2004 Sounds like a pilot jet blockage or an air leak. Most likely the pilot jet though. Take it out, clean it well and blow out with compressed air. Then try it again. Quote Link to comment Share on other sites More sharing options...
