s_preech Posted June 28, 2008 Report Share Posted June 28, 2008 (edited) Hi all, I would just like to start by saying hi, I only registered yesterday after looking at my old Fantic 200 (1980 TX350 i believe) sitting my garage and decided to do something about it. I am having a quite serious problem with the engine. About 6 -7 years ago my brother came off the bike, jamming the throttle wide open for a 20 - 30 seconds. And since it has never been able to start. I have replaced the Plug and the plug wire and it seems to be sparking fine. I have plenty of Fuel in the tank so that does not seem to be the issue. When I kick the bike over it seems to have compression, its only 156cc but its still quite hard to kick. I have split the top casing off the top of the engine, and checked the piston out and it looks fine. Im not really very knowledgable about motorbikes so I have limited knowledge about these sorts of things. So any help would be greatly apprciated. Also im trying to dig out the workshop manual for it. If anyone has a copy of it? Or a scanned copy? I would be willing to pay to have a copy. Thanks in advance Edited June 28, 2008 by s_preech Quote Link to comment Share on other sites More sharing options...
turbo Posted June 28, 2008 Report Share Posted June 28, 2008 woodruff key may be Quote Link to comment Share on other sites More sharing options...
s_preech Posted June 28, 2008 Author Report Share Posted June 28, 2008 Thanks for the info Turbo. Do you think I should split the engine to see if something is mechanically incorrect inside? I think that is where the Woodruff key is. Sorry about my low level of knowledge im new to most things about motorcycle engines. Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted June 29, 2008 Report Share Posted June 29, 2008 the woodruff key is on the flywheel shaft. what it does is it sets the timing for the spark. if the key is cheard then it will still spark but all over the place. if you can get your hands on one use a 12v rattle gun to remove the flywheel nut. from there you will need the correct fly wheel puller to get it off. make sure when you replace the flywheel that the nut is tight as this is what usually causes the key to sheer. hope this helps max Quote Link to comment Share on other sites More sharing options...
s_preech Posted June 29, 2008 Author Report Share Posted June 29, 2008 the woodruff key is on the flywheel shaft. what it does is it sets the timing for the spark. if the key is cheard then it will still spark but all over the place. if you can get your hands on one use a 12v rattle gun to remove the flywheel nut. from there you will need the correct fly wheel puller to get it off. make sure when you replace the flywheel that the nut is tight as this is what usually causes the key to sheer.hope this helps max Thanks max, that is a great help. When I open it up if something is wrong with it then will I definatly see it? And if there is something wrong with it are they a standard thing to replace? Quote Link to comment Share on other sites More sharing options...
s_preech Posted June 29, 2008 Author Report Share Posted June 29, 2008 Update: I have just pulled the flywheel cover off, the flywheel nut was indeed loose. I have to wait for a flywheel puller to get to me, ordering one tomorrow. I just dont know where I can get a Woodruff key from to replace it? Quote Link to comment Share on other sites More sharing options...
axulsuv Posted June 29, 2008 Report Share Posted June 29, 2008 (edited) Hi ; I have no idea where you are so I can't tell you where to go for a woodriff key , but make sure you find/fix the reason it stuck wide open before you start the bike again !!! the keys are out there , it just depends where you are as to how fast you can get one !!! Glenn , Just letting us know what country would give us a direction to send you ! Edited June 29, 2008 by axulsuv Quote Link to comment Share on other sites More sharing options...
s_preech Posted June 29, 2008 Author Report Share Posted June 29, 2008 Hi, Sorry I should really have said that I live in the UK, but I wouldn't mind getting one imported if needed from overseas. Anything to get one really Thanks axulsuv Quote Link to comment Share on other sites More sharing options...
lee harris Posted June 30, 2008 Report Share Posted June 30, 2008 phone bill Bill Pye, Frankfield Garage, Great Ayton, Middlesbrough, North Yorks, TS9 6BZ (Tel 01642 722378) he has all the woody keys you will need lee Quote Link to comment Share on other sites More sharing options...
s_preech Posted July 1, 2008 Author Report Share Posted July 1, 2008 Update: The flywheel puller arrived from Inmotion Trials. Popped the flywheel off and the woodruff key had been completly snapped off ;p Pretty much clean against the shaft. Thank you sooo much Lee, ill give him a call tomorrow and sort out a Woodruff key. Thanks everyone that has helped, the comunity on these boards is absolutly outstanding. Thanks Quote Link to comment Share on other sites More sharing options...
bilc0 Posted July 1, 2008 Report Share Posted July 1, 2008 Use a torgue wrench to tighten the flywheel nut up,bill should be able to help with the correct wrench setting,the nut like's to be nice and tight on them. Quote Link to comment Share on other sites More sharing options...
s_preech Posted July 1, 2008 Author Report Share Posted July 1, 2008 Thanks for the tip Bilc0 I don't have a torque wrench, do you know where I can get one? preferably on the cheap. Quote Link to comment Share on other sites More sharing options...
lee harris Posted July 2, 2008 Report Share Posted July 2, 2008 tighten till threads strip then back half a turn? try halfordords @Bilco...still on for Bilsdale? Quote Link to comment Share on other sites More sharing options...
bilc0 Posted July 2, 2008 Report Share Posted July 2, 2008 @Bilco...still on for Bilsdale? yep... must be getting to the time to tap bill up for reg's. Quote Link to comment Share on other sites More sharing options...
s_preech Posted July 2, 2008 Author Report Share Posted July 2, 2008 In the end I ordered this one https://www.screwfix.com/prods/18289/Hand-T...s/Torque-Wrench So hopefully that will be ok. Just out of interest does anyone have the torque settings for the whole engine? Stuff like the top bolts of the piston head etc? Might aswell do the job proper ;p Quote Link to comment Share on other sites More sharing options...
