Foot Peg Bracket
bowellsyboy
Hi, ive got a beta rev - 3 06 and have just replaced my right footpeg bracket for the 3rd time, after bending it again!! It is the original type from beta. Having looked at it the support triangle piece on it only seems to be spot welded on and doesnt look very strong. I was thinking of welding it a bit more to make it more solid. What i want to know is, is it designed like that so the bracket gives before the frame bends or can i weld away :hl: ? Has anyone else had this problem?
Hi, ive got a beta rev - 3 06 and have just replaced my right footpeg bracket for the 3rd time, after bending it again!! It is the original type from beta. Having looked at it the support triangle piece on it only seems to be spot welded on and doesnt look very strong. I was thinking of welding it a bit more to make it more solid. What i want to know is, is it designed like that so the bracket gives before the frame bends or can i weld away ^_^ ? Has anyone else had this problem?
I always weld the triangular gusset, it will make it stronger but not as strong as the frame so it will take lots of knocks before bending again :hl:
