Majesty Frame
rock hopper
The Mini Majesty frame for the TY175 motor has a wheelbase shorter than a TY175 frame and a steeper head angle.
The series 1 Majesty 175 is based on the standard TY175 frame and shares the same wheelbase and steering head angle as the TY175 frame.
The Godden Majesty made for the TY175 motor has a longer wheelbase than the TY175 frame and a steeper head angle.
When was the Godden Majesty frames made and do you know what the head angle, wheel base were.
Assuming you mean Godden Majesty frame for TY175 motor
Early 1980s
Appears to be the same angle as standard Yamaha TY250 and Godden 250/320 frame.
Only know for sure that the wheelbase is longer than the TY175. Suspect it is the same as Godden 250/320 which is 25mm longer than TY250.
