astrolounger Posted December 12, 2003 Report Share Posted December 12, 2003 How much play[movement] should there be in swing arm linkage.98 Scorpa,up on a stand with the rear wheel off.The play is verticle not side to side.It does not feel loose or sloppy but is there when I grab the end of the S A and move it.So how much,if any is normal? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted December 14, 2003 Report Share Posted December 14, 2003 I'm not totally familiar with your Scorpa, but I'm assuming that, like the new ones, it has linkage-less suspension, so taking care of slop is probably just a matter of new bushings in the end of the shock...no dogbones to deal with. Also...remember that slop is going to seem to increase with the length of the swingarm. A few thousandths of an inch can be 3/8" at the axle. So, a little slop is no big deal...even with new bearings or bushings, a little play will appear after a few rides. Quote Link to comment Share on other sites More sharing options...
astrolounger Posted December 15, 2003 Author Report Share Posted December 15, 2003 Thanks for the answer Charlie.The 98 is the link type[dog bones]I guess Mike at the Tryals shop would be able to give me the answer I need. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted December 15, 2003 Report Share Posted December 15, 2003 This is off the top of my head, but I'd say that if you get to about 1/2" of slop at the axle, the bearings are pretty much whipped. It's a pretty easy fix, and you can figure on doing it about once a year. A mid-year clean-and-grease wouldn't hurt, either. I'm sure Mike stocks the bearings and can hook you up in a jiffy. Quote Link to comment Share on other sites More sharing options...
sherpa Posted December 16, 2003 Report Share Posted December 16, 2003 If it is like a sherco, and it most likely is.. there should be no play, that is to say zero. This is with new dog bone bearings and shock bearings. The swing arm bearings, if properly lubed, should last the life of the bike. Quote Link to comment Share on other sites More sharing options...
