steve Posted July 11, 2008 Report Share Posted July 11, 2008 Hello all, I wonder if one of you fine Gas Gas fellows could help me with a couple of measurements. I am looking to replace my fork brace / mudguard bracket on my Montesa Twinshock. I used to have a 94 Gas Gas JT250 and the brace fitted to the Paolli forks would be ideal for me - if it fits! I think they were fitted across the range from 1994 to 2000. Could some kind sole please give me a couple of meaurements? I need the distance between the mounting holes (the bit where it bolts to the fork leg) height of the bracket. (if it does bolt in will there be clearance for my tyre) The other factor is the width from fork to fork but that can easily be bent or stretched to suit Many thanks, Steve Quote Link to comment Share on other sites More sharing options...
peterb Posted July 12, 2008 Report Share Posted July 12, 2008 Hi Steve, Fine Gas Gas sole/soul here. I have a bracket ready to measure: Dist between holes, centre to centre = 65mm Width, to outside of bkt = 100mm Height approx 90mm (One side is higher than the other) These can bend a little to fit, but too much, and the brace distorts way out of shape as happened when I tried to make one fit a TY175. Very hard to get back into shape. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
