Beta Hunting
mrmoog
Hunting at idle usually indicates a slightly lean condition. Disassemble and blow out the carb passages with compressed air. Also if there was a large change in conditions then the jetting can be slightly off. Usually this just an issue when the temperature changes dramatically like between winter and summer.
While you've got the carb apart make sure your floats aren't binding on the bowl gasket and are set at the correct height.
Edited by Dan Williams
I've cleaned out the carb, there was fine dirt at the mouth of the carb, this must have got through the air filter, I'll see what happens.
How do you know if the engine is getting hot, the fan cuts in and out but can you adjust the temp sender to come in at a lower temp?
