scorpa4banger Posted July 13, 2008 Report Share Posted July 13, 2008 Still having trouble starting my 76 sherpa T tried an extra fuel filter pulled the carby apart again and cleaned it all out seems to run okay but I think it floods way too easy the float and inlet valve thing is all clean and in good condition but its still really hard to start oh and the spark is really good tried new plugs also is there a differant carby you can get to work other than the Amal carb ? if so whats the brand size and spec's ?? also after taking the plug out and clearing it ive also tried the tipping it over to the side trick and it still is a bugger to start any help would be great cheers Quote Link to comment Share on other sites More sharing options...
swooshdave Posted July 13, 2008 Report Share Posted July 13, 2008 We are assuming everything is clean. Have all the wear-prone parts been replaced? Have all the jets been replaced? Is the slide tight in the body? Fixing the existing carb should be less expensive than replacing it. But many people swear that a Mukuni or the like is much better. They are too complicated for me. But I'm just a simple lad. Quote Link to comment Share on other sites More sharing options...
hightown Posted July 13, 2008 Report Share Posted July 13, 2008 Hello Scorpa4banger I had the same problem with my 79 Bultaco 250, It turned out to be the jet at the bottom of the choke chamber was blocked once it was cleaned it starts on the second or third kick . Hope this helps Eddie Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 14, 2008 Report Share Posted July 14, 2008 you sure the electrics are spot on timing condenser plug cap and coil,no lighting connections etc? Quote Link to comment Share on other sites More sharing options...
