Rev3 Fan Not Working
adam
Just fixed a problem on an 07 250. The fan only worked when revs were off tickover. The cause was the black box as described previously was not mounted on the bolt behind the radiator. It seems to earth through the mounting bolt and was sparking. Once reconnected it worked fine. The bike has not been a great starter from cold bot now seems to be.
I had the same problem on my '02. The black box (I can't remember what it's called) went bad. The way I found out was the yellow wire coming out of it wasn't providing any juice, but it had juice going in.
Not too long after that, the switch on the rad went bad, but that was easy to figure out.
Just get a tester and you should be able to find the problem.
