bsabantamtrials Posted July 15, 2008 Report Share Posted July 15, 2008 hi. does any one know how to straighten greeves scottish leading link forks. thanks charlie Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted August 20, 2008 Report Share Posted August 20, 2008 If the forks on the Scottish are misaligned due to a fall then slacken off the two bolts beneath the bars the bolt heads are visible either side of the top yoke, unscrew about 6mm then tap them vertically downwards this action releases the tapers that secure the top yoke. grip the wheel and re-align everything then re-tighten the top yoke bolts. These bolts must be slackened off when adjusting the head races, good luck. TRF Quote Link to comment Share on other sites More sharing options...
