rock hopper Posted July 18, 2008 Report Share Posted July 18, 2008 What wt oil should I use 5,10 ,15 20 ?I have used 10 but forks seem to rebound fast Quote Link to comment Share on other sites More sharing options...
02-apr Posted July 19, 2008 Report Share Posted July 19, 2008 I think you need to revise the damping mechanism. I knew someone who had one when they were current and even 80w oil did not give good damping in the standard forks. Quote Link to comment Share on other sites More sharing options...
tony283 Posted July 19, 2008 Report Share Posted July 19, 2008 I assume you have the forks set correctly in the yokes? You should have about 1/2 inch protruding through the top yoke, if not it will steer and rebound like a Harley. If the springs are good use either 10 or 15 wt and about 150cc a leg. Tony Quote Link to comment Share on other sites More sharing options...
rock hopper Posted July 20, 2008 Author Report Share Posted July 20, 2008 The book says 126 cc, so you add more to help damping? Quote Link to comment Share on other sites More sharing options...
