geebee Posted July 19, 2008 Report Share Posted July 19, 2008 I am about to start a clutch basket change out on the sherco, using a new basket and the installation kit. This involves the riveting of the assembly. Although I have previous experience of fitting solid rivets could anyone offer any usefull advice on the same and possible areas to avoid. Can this task be implemented using a rivet snap (dolly) or will I require some form of press? Thanks in anticipation - Geebee Quote Link to comment Share on other sites More sharing options...
zippy Posted July 19, 2008 Report Share Posted July 19, 2008 (edited) I took the easy way and ordered it pre-assembled when I had to change mine. no riveting involved. Edited July 19, 2008 by ZIPPY Quote Link to comment Share on other sites More sharing options...
copemech Posted July 19, 2008 Report Share Posted July 19, 2008 The parts book shows them as a 4mm diameter rivet. I would think you could set them with a common shop air hammer with a flat tool while backing up the end against an anvil surface. But, I have never had to do these specific parts. Maybe phone your importer for more info. Quote Link to comment Share on other sites More sharing options...
geebee Posted July 20, 2008 Author Report Share Posted July 20, 2008 Thanks Guys Geebee Quote Link to comment Share on other sites More sharing options...
