Brakes
steam
After aplying copaslipping to the back of the brake pads (front and rear) on riding the bike their efficiency was reduced by about 50%. No grease was on the pads or discs. The front brake would not even lock the wheel when the bike was pushed.
I then tried the trick of riding the bike with the brake applied for 5 mins then sprayed cold water onthe disc and pads. The brake is now good. WHY does this work and WILL the brake remain good.
