jonno Posted July 26, 2008 Report Share Posted July 26, 2008 Hi all, recently bought an 02 gas gas txt pro in an attempt at getting back into trials. bikes perfect but the clutch is reall really stiff. When i bought it the bike was still slightly pulling when the clutch was pulled in but not enough to stall the bike. A bit of adjustment soon sorted this. However its still stiff. Was just wondering if anyone knew what this could be? Thanks in advance, Jonny Quote Link to comment Share on other sites More sharing options...
jse Posted July 26, 2008 Report Share Posted July 26, 2008 Hi all, recently bought an 02 gas gas txt pro in an attempt at getting back into trials. bikes perfect but the clutch is reall really stiff. When i bought it the bike was still slightly pulling when the clutch was pulled in but not enough to stall the bike. A bit of adjustment soon sorted this. However its still stiff. Was just wondering if anyone knew what this could be?Thanks in advance, Jonny Jonny, My first guess is that the two o-rings on the servo cylinder tower (down on the clutch sidecover) need replacing as they may have swollen. While you're down there, you may want to measure the clutch finger height (should be around 17-17.5mm) and they may be too low (thick clutch pack) which will also make the clutch "stiff". Jon Quote Link to comment Share on other sites More sharing options...
jonno Posted July 28, 2008 Author Report Share Posted July 28, 2008 Thanks Jon, Ill get into it and see whats what, thanks for your help Quote Link to comment Share on other sites More sharing options...
