Fuel Tank
postmanpat
Hello mate, I repaired my tank with Arildite. depends where the crack is and how big it is.Mine was where the kickstart sits,tryed petrol patch but after a while it started to leak again,hope this helps.
There is a product called Plastex that works a treat. It comes in different colours, and the blue is not a bad match for Scorpa blue. it can be sanded and painted when dry.
Their website is:
Plastex
You can also get it professionally plastic welded. The base material is a type of Nylon.
Paul
The Hell Team.
There is a two part plastic bonding developed for bumpers, mudguards and fairings, its also suitable for fuels. Its called B2. Mix it 50/50 and it goes of to the touch in about twenty minutes, leave it for 24hrs and you can sand and paint it. Its realy tough and normally prodces a fix stronger than the original nylon or plastics, sadly only in black.
The only other solution I have used in the past and found it worked realy well on a fuel tank was fibreglass. More work and preparation but its pretty permanent.
Edited by renegade
Cheers,where do you get the B2?
Sorry for the delay in my reply, I've been away for a few days.
Its manufactured and sold under the following companies products JB Weld
http://www.jbweld.net/products/uses.php
Part No. 8277 its called waterweld on this site you can even use it in a wet fuel tank.
I purchased mine through Silverstone factors at Silverstone. But you can buy it online.
regards renegade
Edited by renegade
  • 5 weeks later...
