mickh Posted July 28, 2008 Report Share Posted July 28, 2008 at a trial on sunday i found that when i first opened the throttle the engine hesitated at first then as the revs rose it cleared and revved perfectly. the carb has been cleaned jets blown out etc and a new plug fitted. any help would be greatly appreciated mickh Quote Link to comment Share on other sites More sharing options...
jer Posted July 28, 2008 Report Share Posted July 28, 2008 I used to have a TY that got a bit confused until i really cleaned the exhuast out, as in the whole exhuast, not just the silencer. I cut the front off the middle box, burnt out loads of gunk and carbon with a gas torch then repacked it, it ran really well after that. You don't have to cut the front off the box though, running a gas flame through it untill it's really hot does the same, but it did let me see what a state it was in, all the holes in the baffle were clogged and the diameter had narrowed quite a bit. The confused running was a problem that crept up slowly, not one that suddenly appears so not sure if it's your problem. Quote Link to comment Share on other sites More sharing options...
mickh Posted July 28, 2008 Author Report Share Posted July 28, 2008 thanks jer. just cleaned out and re-packed bith silencers about a month ago. however i didnt notice this problem when i refitted then mickh Quote Link to comment Share on other sites More sharing options...
tt5th Posted July 28, 2008 Report Share Posted July 28, 2008 Clean the carb again? Air filter obviously but I'm sure you've done that. It sure sounds like a blockage in your pilot jet. If you have good spark, good air, good fuel then could the timing have slipped? I've heard of woodruff keys shearing allowing this to happen but to be honest I have no idea what one is or even if a TY has one! Quote Link to comment Share on other sites More sharing options...
tt5th Posted July 29, 2008 Report Share Posted July 29, 2008 How about a restriction in the fuel running to the carb? Kinked fuel line or blockage in the tank tap? Quote Link to comment Share on other sites More sharing options...
eiger Posted July 29, 2008 Report Share Posted July 29, 2008 Fuel height in the float chamber is critical. Too high and it'll sound like its choking up on up to quarter throttle, beyond that its fine. Can't remember the measurements but I'll try and dig out the manual Eiger Quote Link to comment Share on other sites More sharing options...
mickh Posted July 30, 2008 Author Report Share Posted July 30, 2008 cheers eiger still got the manual when i bought the bike new. ill check that tomorrow and see if alls ok Quote Link to comment Share on other sites More sharing options...
