How Do I Find Out If I Have Boyesen Reeds And What Is Quckest Way To Take Carb Out?
matt_tily
  • 4 weeks later...
hey there,
to find out if you have boyesen reeds, you will have to remove the reed block (the thick block that bolts to the crankcase, 4 bolts). If you have Boyesen's then they will be 4 ultra-thin pieces of yellow plastic (may be dirty from fuel).
There is no easy way to clean the barb out, you will have to take the airbox off to do this.
thanks
rob margetts
