4rt Fan Help
shnaft
Hi, just bought a 4rt,rode it today i let the bike warm up until fan came on and set of,but all the time i was out the fan stayed on is this normal,also is it true they have a saftey device that cuts the engine if it were to overheat,
If the engine overheats there is whats probably best described as a ' limp home mode '
Bike will start and run fine up to 2500 rpm then rev limiter cuts in. Letting the engine cool down and the ecu returns to normal.
Ride it, take your gloves off and feel how warm the fuel tank gets, then you understand why the fan is on so much
